Cisco ISE VM interface with same IP range
Freemen
Hi All
I know can assign difference IP to difference interface example .200 Gi0 .201 Gi1 then share the same default gateway.
so question is example, if AAA client (WLC) point to .201 for Radius request, will it possible ISE to reply on wrong interface and cause something like mac spoofing / asymmetric routing
are this kind of design even work?
paul
Level 10
Level 10
I am not sure why you would want to do this, but each interface has its own MAC address so MAC issues wouldn't be a thing.  By default for traffic sent to ISE it will send it back out the same interface it arrived on so the RADIUS responses should go out the same interface.  For traffic initiated by ISE I believe it follows the routing table.
