Cisco ISE Web interface problem
teymur azimov
Level 7
Level 7
Hi Dears,
I did initial configuration to Cisco ISE 3315. I wrote username and password in iintial setup. All of them are ok in CLI. I can access that username and password in CLI mode. Then I want to access web interface. The ISE page is open and i type the username and password(which i typed in initial setup).But i can not acces ISE. I try to use the default username and password which is admin/cisco and it is also fail.
I try to configure the new username and password in CLI and then try access the new one but this is also fail.
I did restart the device but this is not help.
I do not know what is a problem
Is it a sofware version bug?? or I need to do additional configuration for web-based interface??
I erase the password policy which is default have in ISE. but the problem is not solved.
please help me.
Saurav Lodh
Level 11
Level 11
Please follow similiar discussions from here
https://supportforums.cisco.com/thread/2162667
Charlie Moreton
Teymur,
If you can log in to the CLI, use this command to set the password for the CLI:
application reset-passwd ise admin
You will then be prompted to enter the new password and then to confirm it.  The admin accounts for the CLI and for the WebGUI are different accounts and should have been synchronized during the initial setup, but may have been changed.
If your CLI account has the proper priveliges, the command above will work.
Please Rate Helpful posts and mark this question as answered if, in fact, this does answer your question.  Otherwise, feel free to post follow-up questions.
Charles Moreton
