Cisco Secure ACS 5.4/Monitoring and Report Viewer - SNMP Settings
r-westphal
Hello Everyone.
I hope this is the right forum for my question.
We just purchased 8 1121 ACS 5.4 appliances. I have some familiarity with the older 1113 and 1120 appliances running ACS 4.2. So I have a lot to learn.
Right now I'm trying to understand the Monitoring and Report Viewer System Configuration. I set the SNMP V2 read comm. string to the same string I configured from the CLI.
etc-labacsb1-1/admin# show runn | inc snmp
snmp-server contact "ACS1121;XXXXX"
snmp-server location "B1 Lab"
snmp-server community XXXXXX ro
1) It was not the same string as configured on CLI. Does setting this give me access to query more than system type or server type MIB objects.
2) Can you provide an example? (for example to query a switch -  snmpwalk -v 1 -c XXXXXX hostname 1.3.6.1.4.1.9.9.43)
3) What is the MIB object tree OID (1.3.6.1.4.1.9.???) for these ACS appliances?
Thanks in advance.
Ray Westphal
EHI
Jatin Katyal
Have you gone through this
http://www.cisco.com/en/US/products/ps9911/products_configuration_example09186a0080bcc208.shtml#req
~BR
Jatin Katyal
**Do rate helpful posts**
~Jatin
Thanks Jatin.
Based on the doc. - it looks like this provides no additional SNMP query access.
Ray Westphal
EHI
that's correct. here is what we have in ACS 5.4 for snmp.
ACS 5.4 supports Simple Network Management Protocol (SNMP) to provide logging services. The SNMP agent provides read-only SNMPv1 and SNMPv2c support. The supported MIBs include:
•SNMPv2-MIB
•RFC1213-MIB (MIB II)
•IF-MIB
•IP-MIB
•TCP-MIB
•UDP-MIB
•CISCO-CDP-MIB
•ENTITY-MIB
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.4/device_support/sdt54.html#wp71020
~BR
Jatin Katyal
~Jatin
