Cisco Secure ACS Solution engine v3.2
david.yu
Community Member
The ACS Soultion Engine appliance hardware by default comes with two NICs. Can I configure it so one Nic be on VLAN 30 and the other Nic be on VLAN 50?
VLAN 30 - will be the network that communicate or forward credential to ACS Remote Agent for Windows authentication.
VLAN 50 - will be for network devices authetication. RAIDUS or TACAUS.
jasjsingh
This is not possible as only one nic works at a time . ( Check for Back Panel features)
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacsapp/csapp33/install/ovrvuap.htm#wp1046176
Jasjeet
jasjsingh
Jasjeet
