Cisco Wireless Authentication
ejdrijin1
Level 3
Level 3
Is it possible to make authentication with both user and computer certificates with a Windows Network Policy Server?
Thanks.
Yes, you can use the Cisco Network Access Manager (NAM) to authenticate to you NPS server, it basically replaces the windows native supplicant and supports several authentication modes.
Ben Walters
Level 9
Level 9
It really depends on the client's supplicant, the Windows native supplicant will not handle both user and machine authentication, it is one or the other.
If you use Cisco AnyConnect as a supplicant you can do EAP chaining which allows authentication of both user and machine at the same time. However I can't say for sure if the AnyConnect supplicant will do EAP chaining with a Windows NPS.
Thanks for your reply.
So you can use cisco any connect as your client and authenticate with the Windows NPS?
I am assuming that you will use the cisco network manager, right?
Thanks.
