Cisco Wireless Controller authentication with ISE for both wireless users and device admin
josephqiu
Level 3
Level 3
We deployed Cisco WLC and currently use the ISE/RADIUS to authenticate wireless users for network access. This is in a good working state right now. What I’m trying to do is to enable TACACS on the WLC and authenticate admin users for management access using the same ISE server. Is this at all possible? Reason I’m asking is WLC is already using a policy for RADIUS/EAP. How can I differentiate the WLC and match the TACACS request from the same WLC management IP and apply a different policy? Thanks
2 Accepted Solutions
RaffyLindogan
Hi mate,
TACACS and RADIUS config on ISE and WLC are 2 separate things.
When traffic reach ISE, it will know if it is for TACACS or RADIUS and you can have separate conditions for them on the policy set.
So you don't have to worry about messing your existing RADIUS configuration.
On the ISE, when you click on WLC. there's part for RADIUS Authentication Settings and TACACS Authentication Settings.
Same as on the actual WLC config as well.
Cheers,
Raffy
Here are 2 good links that you can use as reference:
 https://networkproguide.com/how-to-configure-cisco-wlc-tacacs-cisco-ise-2-4/
https://community.cisco.com/t5/security-documents/cisco-ise-device-administration-prescriptive-deployment-guide/ta-p/3738365#toc-hId--2121451074
As Raffy said the configuration for RADIUS and TACACS are completely separated.
Policy->Policy Sets is the RADIUS side of ISE
Work Centers->Device Administration->Device Admin Policy Sets is the TACACS side
Also as a best practice you should part out your wireless policy sets into use cases based on SSID.  You can use the RADIUS called station ID attribute sent by the WLC to tell what SSID the user is connecting to and write different policy sets based on that.
RaffyLindogan
Hi mate,
Cheers,
Raffy
Thank you Paul. Yes, that’s what I’m doing with the wireless auth policy. Much appreciated.
Thank you for your reply. Looks like I worried too much. 🙂
