conectivity problem with port based authentication
m_meraj
Community Member
HI,
I could not able to autheticate through acs 3.3 on windows xp client, ACS is connected to core sw 4006 and my client is also connected to same sw.
when I debug dot1x I got this message. could anybody tell me where is the problem.
" 4w0d: dot1x-ev:Delaying initial EAP-Request/Identity packet
4w0d: dot1x-ev:Received pkt saddr =000e.7f61.25db , daddr = 0180.c200.0043 ,
pae-ether-type = 34958
4w0d: dot1x-ev:Received AuthStart from Authenticator
4w0d: dot1x-ev:Managed Timer in sub-block attached as leaf to master
4w0d: dot1x-ev:Going to Send Request to AAA Client on RP for id = 1 and length =
9
4w0d: dot1x-ev:Got a Request from SP to send it to Radius with id 112
4w0d: dot1x-ev:Couldn't Find a process thats already handling the request for this id 1
4w0d: dot1x-ev:Found a free slot at slot 0
4w0d: dot1x-ev:Created a New process with Id 62
4w0d: dot1x-ev:Successfully created a process to handle this aaa request
4w0d: dot1x-ev:Inserted the request on to list of pending requests
4w0d: dot1x-ev:Request id = 112 and length = 9
4w0d: dot1x-ev:The Interface on which we got this AAA Request is GigabitEthernet 4/7
4w0d: dot1x-ev:Username is test
4w0d: RADIUS: ustruct sharecount=1
4w0d: RADIUS: EAP-login: length of radius packet = 73 code = 1
4w0d: RADIUS: Initial Transmit GigabitEthernet4/7 id 111 10.102.10.6:1812, Access-Request, len 73
4w0d: Attribute 4 6 0A6603FE
4w0d: Attribute 61 6 00000000
4w0d: Attribute 1 6 74657374
4w0d: Attribute 12 6 000003E8
4w0d: Attribute 79 11 02010009
4w0d: Attribute 80 18 093B78F5
4w0d: RADIUS: Received from id 111 10.102.10.6:1812, Access-Reject, len 56
4w0d: Attribute 79 6 04000004
4w0d: Attribute 18 12 52656A65
4w0d: Attribute 80 18 702E0914
4w0d: RADIUS: EAP-login: length of eap packet = 4
4w0d: RADIUS: EAP-login: got reject from radius
4w0d: dot1x-ev:going to send to backend on SP, length = 4
4w0d: dot1x-ev:Received VLAN is No Vlan
4w0d: dot1x-ev:Enqueued the response to BackEnd
4w0d: dot1x-ev:The process does its job, so killing itself
4w0d: dot1x-ev:Received QUEUE EVENT in response to AAA Request
4w0d: dot1x-ev:Dot1x matching request-response found
4w0d: dot1x-ev:Length of recv eap packet from radius = 4
RIY-CC-IT-CORE#
4w0d: dot1x-ev:Received VLAN Id -1
4w0d: dot1x-ev:dot1x_bend: Sending Radius Response to Supplicant of length 4"
jafrazie
Not enough info. Doesn't look like the complete transaction. Why does ACS tell you the service attempt has failed?
