10-13-2014 04:20 AM - edited 03-10-2019 10:06 PM
I am implementing DOT1X on a Secure ACS 5.3 that supports 2 separate network that I have created two LDAP instances. So far so good! both connect to the LDAP servers, I can authenticate via TACACS+ and Radius, but the MAC authentication that I require is not functioning, can someone assist with this? any step by step documentation that can walk me through this and on the network devices would be greatly appreciated.
10-13-2014 06:50 PM
http://www.cisco.com/c/en/us/support/docs/security/secure-access-control-system/113566-nac-ldap-acs5-config-00.html
10-13-2014 09:41 PM
Thank you Salodh,
question in the document it mentions a " Beacon Endpoint Profiler" is the necessary for the process since I have already established an LDAP connection?..
Cheers!
