Configuring Inaccessible Authentication Bypass and Critical Voice VLAN, togheter with guest VLAN
Kjetil Fleten
On a Catalyst 2960, I'm trying to allow a IP phone and a computer on the same port, and verify those devices against RADIUS (ISE). Unauthenticated devices should be placed in guest VLAN. In the event of a RADIUS failure, no device should be placed in guest, but go to the access vlan.
When authentication fails for a device, it goes to guest VLAN 50, as desired. When RADIUS is down, it should bypass authentication and go to access VLAN, but it does not. Why ?
My port setting and RADIUS setup looks like this:
interface GigabitEthernet1/0/5
 switchport access vlan 5
 switchport mode access
 switchport voice vlan 6
 authentication event server dead action authorize vlan 5
 authentication event server dead action authorize voice
 authentication event no-response action authorize vlan 50
 authentication host-mode multi-auth
 authentication order dot1x mab
 authentication priority dot1x mab
 authentication port-control auto
 authentication periodic
 authentication timer reauthenticate server
 mab
 mls qos trust dscp
 dot1x pae authenticator
 dot1x timeout tx-period 10
 spanning-tree portfast
end
radius-server attribute 6 on-for-login-auth
radius-server attribute 8 include-in-access-req
radius-server dead-criteria time 120
radius-server retry method reorder
radius-server transaction max-tries 3
radius server ISE
 address ipv4 [omitted by me] auth-port 1812 acct-port 1813
 key [omitted by me]
Output from switch when I connect:
%DOT1X-5-FAIL: Authentication failed for client (001e.330c.7871) on Interface Gi1/0/5 AuditSessionID C0A80BDC0000008F013B8CF6
Mar 30 07:12:28.821: AAA/AUTHEN/8021X (00000000): Pick method list 'default'
Mar 30 07:12:28.821: AAA/AUTHEN(00000000): There is no General DBReply Method Index details may not be specified
Kjetil
PedroReforco
For me it get's worse...I wan't it to go to VlanGuest and it won't...ever...I compared my port configuration with yours and it's almost identical...
Config from my port:
interface FastEthernet0/28
 switchport access vlan 100
 switchport nonegotiate
 switchport voice vlan 113
 switchport port-security maximum 2
 srr-queue bandwidth share 1 30 35 5
 priority-queue out
 authentication event fail action authorize vlan 165
 authentication order mab dot1x
 authentication priority mab dot1x
 authentication timer restart 120
 authentication timer inactivity 600
 mab
 mls qos trust device cisco-phone
 mls qos trust cos
 auto qos voip cisco-phone
 storm-control broadcast level 20.00
 storm-control action trap
 spanning-tree bpdufilter enable
 spanning-tree bpduguard enable
 spanning-tree guard loop
 service-policy input AUTOQOS-SRND4-CISCOPHONE-POLICY
end
Errors from switch when plugging to the port
045739: May 29 16:35:21.045 PT: %AUTHMGR-5-START: Starting 'mab' for client (d4be.d953.4e2d) on Interface Fa0/28 AuditSessionID 0A07FF0100001448E5D4800E
045740: May 29 16:35:21.054 PT: %MAB-5-FAIL: Authentication failed for client (d4be.d953.4e2d) on Interface Fa0/28 AuditSessionID 0A07FF0100001448E5D4800E
045741: May 29 16:35:21.054 PT: %AUTHMGR-7-RESULT: Authentication result 'no-response' from 'mab' for client (d4be.d953.4e2d) on Interface Fa0/28 AuditSessionID 0A07FF0100001448E5D4800E
045742: May 29 16:35:21.062 PT: %AUTHMGR-7-FAILOVER: Failing over from 'mab' for client (d4be.d953.4e2d) on Interface Fa0/28 AuditSessionID 0A07FF0100001448E5D4800E
045743: May 29 16:35:21.062 PT: %AUTHMGR-5-START: Starting 'dot1x' for client (d4be.d953.4e2d) on Interface Fa0/28 AuditSessionID 0A07FF0100001448E5D4800E
045744: May 29 16:35:22.866 PT: %LINK-3-UPDOWN: Interface FastEthernet0/28, changed state to up
045745: May 29 16:35:23.872 PT: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/28, changed state to up
045747: May 29 16:36:53.691 PT: %AUTHMGR-7-RESULT: Authentication result 'no-response' from 'dot1x' for client (d4be.d953.4e2d) on Interface Fa0/28 AuditSessionID 0A07FF0100001448E5D4800E
045748: May 29 16:36:53.691 PT: %AUTHMGR-7-FAILOVER: Failing over from 'dot1x' for client (d4be.d953.4e2d) on Interface Fa0/28 AuditSessionID 0A07FF0100001448E5D4800E
045749: May 29 16:36:53.691 PT: %AUTHMGR-7-NOMOREMETHODS: Exhausted all authentication methods for client (d4be.d953.4e2d) on Interface Fa0/28 AuditSessionID 0A07FF0100001448E5D4800E
QL-SW1#
045750: May 29 16:36:53.699 PT: %AUTHMGR-5-FAIL: Authorization failed for client (d4be.d953.4e2d) on Interface Fa0/28 AuditSessionID 0A07FF0100001448E5D4800E
Hi!!!
Mine is working allready... here's my configuration, please check if it works with you!
Here's the input:
priority-queue out
mab
mls qos trust cos
dot1x mac-auth-bypass
dot1x critical recovery action reinitialize
dot1x port-control auto
 dot1x host-mode multi-host
dot1x control-direction in
dot1x timeout quiet-period 2
dot1x timeout server-timeout 2
dot1x timeout reauth-period server
dot1x timeout supp-timeout 2
dot1x max-reauth-req 1
dot1x reauthentication
dot1x guest-vlan 166
dot1x auth-fail vlan 166
The output came out with sintax fixed for the 2960 model:
shutdown
priority-queue out
authentication control-direction in
authentication event fail action authorize vlan 166
authentication event no-response action authorize vlan 166
authentication event server alive action reinitialize
authentication host-mode multi-host
mab
mls qos trust cos
end
And the Terminal monitor Output is like this :
046200: May 29 18:01:32.251 PT: %AUTHMGR-5-START: Starting 'mab' for client (d4be.d953.4e2d) on Interface Fa0/28 AuditSessionID 0A07FF010000146BE62367DB
046201: May 29 18:01:32.268 PT: %MAB-5-FAIL: Authentication failed for client (d4be.d953.4e2d) on Interface Fa0/28 AuditSessionID 0A07FF010000146BE62367DB
046202: May 29 18:01:32.268 PT: %AUTHMGR-7-RESULT: Authentication result 'no-response' from 'mab' for client (d4be.d953.4e2d) on Interface Fa0/28 AuditSessionID 0A07FF010000146BE62367DB
046203: May 29 18:01:32.268 PT: %AUTHMGR-7-FAILOVER: Failing over from 'mab' for client (d4be.d953.4e2d) on Interface Fa0/28 AuditSessionID 0A07FF010000146BE62367DB
046204: May 29 18:01:32.268 PT: %AUTHMGR-5-START: Starting 'dot1x' for client (d4be.d953.4e2d) on Interface Fa0/28 AuditSessionID 0A07FF010000146BE62367DB
046205: May 29 18:01:34.097 PT: %LINK-3-UPDOWN: Interface FastEthernet0/28, changed state to up
046206: May 29 18:01:34.332 PT: %DOT1X-5-FAIL: Authentication failed for client (d4be.d953.4e2d) on Interface Fa0/28 AuditSessionID
046207: May 29 18:01:34.332 PT: %AUTHMGR-7-RESULT: Authentication result 'no-response' from 'dot1x' for client (d4be.d953.4e2d) on Interface Fa0/28 AuditSessionID 0A07FF010000146BE62367DB
046208: May 29 18:01:34.332 PT: %AUTHMGR-7-FAILOVER: Failing over from 'dot1x' for client (d4be.d953.4e2d) on Interface Fa0/28 AuditSessionID 0A07FF010000146BE62367DB
046209: May 29 18:01:34.332 PT: %AUTHMGR-7-NOMOREMETHODS: Exhausted all authentication methods for client (d4be.d953.4e2d) on Interface Fa0/28 AuditSessionID 0A07FF010000146BE62367DB
046210: May 29 18:01:34.332 PT: %AUTHMGR-5-VLANASSIGN: VLAN 166 assigned to Interface Fa0/28 AuditSessionID 0A07FF010000146BE62367DB
046211: May 29 18:01:35.112 PT: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/28, changed state to up
046212: May 29 18:01:35.322 PT: %AUTHMGR-5-SUCCESS: Authorization succeeded for client (Unknown MAC) on Interface Fa0/28 AuditSessionID 0A07FF010000146BE62367DB
