Connecting to VPN3030 using ACS 3.1.1 authentication question
zabbas
Is it possible using ACS to not only allow users using a Cisco VPN Client the ability to authenticate to a VPN 3000 concentrator, but also the ability to change their password ? We currently use ACS 3.1(1)
We are currenlty using a Win2000 domain via the ACS box to authenticate users, we would like to remove the domain from the current setup and just use ACS. The problem we encountered with earlier versions of ACS was once a user id/pass was setup, the user had no ability to change their password (using the cisco client) when logging into vpn for the first time, or the ability to expire a user password after 6 months and then prompt them for a new one. We don't want to have to give users a utility to install to do this.
Is this functionality available in ACS 3.1(1) ?
gfullage
Already answered in Security - AAA forum.
