Conversion Exception on REST Call
paul
Level 11
Level 11
I have an odd error when I query the guest types on my lab deployment running 2.3 patch 2.
https://10.89.80.34:9060/ers/config/guesttype
    "ERSResponse": {
        "operation": "GET-getAll-guesttype",
        "messages": [
                "type": "ERROR",
                "code": "Conversion exception"
        "link": {
            "rel": "related",
            "href": "https://10.89.80.34:9060/ers/config/guesttype",
            "type": "application/xml"
I can make the same query without issue to a customer's deployment.  Not sure what the conversion exception means.  I can query other stuff from ISE via API (endpoints, DACLs, etc.).  Does it mean I have a bad guest type of some sort?
hslai
I opened CSCvi07975 on the filter issue. Please wait for a couple of days before it externally visible.
If you get the same error again, please turn on debug on ers and check ise-psc.log and guest.log.
The API doc says,
CONVERSION_EXCEPTIONOccurs for some internal conversions and should be treated as INTERNAL_EXCEPTION
paul
Level 11
Level 11
Well I guessed it was something with the guest types it didn't like.  I deleted all the custom ones I created, then the query worked.  Then I rebuilt the guest types I wanted and it still works.
One oddity is that the filter by name doesn't appear to work.
https://10.89.80.34:9060/ers/config/guesttype?filter=name.eq.Guest_Daily
I have a guest type called Guest_Daily that the filter doesn't work.  The call just returns all the guest types.
hslai
The API doc says,
