CSM login problem
anva12345
Level 3
Level 3
We get the following error when try to login to Cisco Security Manager. we have tried all options to make it work but went in vein.
""Forbidden
You don't have permission to access /cwhp/LiaisonServlet on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request. ""
Can any one help us to isolate this issue.
Thanks in advance
smahbub
Level 11
Level 11
If you see an error message that says "Forbidden" or "Internal Server Error," the required Tomcat service is not running. Unless you rebooted your server recently and Tomcat has not had enough time yet to start running, you might have to review server logs or take other steps to investigate why Tomcat is not running.
