CWA looped (using ISE2.1 and Catalyst 3850)
Rich Yim
I am setting up a Wired Central Web Authentication demo using ISE 2.1 and Catalyst 3850. I  can successfully see the redirection to Web Authentication portal. After we authentication to the Web Authentication, it looped and redirected me back to the authentication portal again. Below are the captures of what I did. Please help to see if I did anything incorrectly?
Switch interface configuration:
ip access-list extended ACL_WEBAUTH_REDIRECT
permit udp any any eq bootpc
permit udp any eq bootpc any
permit tcp any any eq www
permit tcp any any eq 443
permit tcp any any eq domain
permit tcp any eq domain any
ip access-list extended redirect-acl
permit icmp any any
permit tcp any any eq 8443
permit tcp any eq 8443 any
permit udp any any eq domain
permit udp any eq domain any
interface GigabitEthernet1/0/13
switchport access vlan 101
switchport mode access
ip access-group redirect-acl in
authentication event server dead action authorize vlan 101
authentication event server dead action authorize voice
authentication event server alive action reinitialize
authentication host-mode multi-auth
authentication open
authentication order mab webauth
authentication priority webauth
authentication port-control auto
authentication periodic
authentication timer reauthenticate server
mab
dot1x pae authenticator
spanning-tree portfast
end
ammahend
your ACL does not seems to be right, whatever you permit on switch in redirect ACL is redirected, whatever you deny is not redirected. Typically you would want port 80 and 443 to be redirected (so permit), not dhcp, dns, ise IP etc. (so deny)
So modify your ACL and try again. Let me know
-hope this helps-
hslai
We should use separate ACLs -- one for URL redirect and the other for port ACL. Please see Cisco Switches for more info.
Below are examples for each:
-- ACL for URL redirect --
ip access-list extended ACL-URL-REDIRECT
deny   tcp any host 10.1.100.222 eq www
where 10.1.100.222 is a remediation web site so to "deny" it to allow the requests going through. Since there is an implicit deny, all non-HTTP connections will not trigger web redirect.
-- ACL to apply for default port access --
ip access-list extended ACL-DEFAULT
remark DHCP
permit udp any eq bootpc any eq bootps
remark DNS
remark Ping
permit icmp any any
remark PXE / TFTP
permit udp any any eq tftp
remark Drop all the rest
deny   ip any any log
Rich Yim
To share my troubleshoot result: I found that I missed out the COA configuration on both ISE and the switch configuration. Once the COA configurations were done, the loop problem vanished.
