Cyclades ACS8 with Cisco ACS using TACACS+
craig.juhas
Level 4
Level 4
Hi All,
I'm hoping someone has already gone through this and has a nice answer for me.  I'm looking to integrate our Cyclades ACS Console Servers into our Cisco ACS servers using TACACS+.  At this point it's sort of working but not quite the way I want it to but I don't know what I'm missing.
As it stands I've set up TACACS+ on the Cyclades with TacacsPlus/Local.  If I log in with my own credentials, which are derived from AD, it works but I am classed as a 'Regular User' with only the ability to start console sessions.  What I would like is to be classed as 'Admin'.  I'm guessing this needs setting in the Shell Profile but I don't know what I'm supposed to be specifying.
Please let me know if you know what to specify on the Cisco ACS server to get this working the way I want.
System details are:
The Cyclades ACS8 is running v3.2.1
The Cisco ACS server is running v5.3.0.40
Craig
dchamorro
Craig,
We have all of our Avocents running through LDAP/AD because at the time I couldn't find the right VSA for RADIUS. If you can get either the Radius dictionary or the TACACS attributes that ACS needs to see to map to a shell then I could help you write the profile.
D.C.
That's the part I'm missing at the moment.  I don't know what the TACACS attributes are for the ACS8's so I'm unable to have my login elevated above 'Regular User'.  Once I know what the attribute and value need to be I can add that to the Shell Profile and I'll be set.  It's just getting that list which is proving a challenge!
