Device-Sensor Profiling Doesn't Appear To Be Working
loverbey
Devices are configured with device-sensor CDP, LLDP and RADIUS:
device-sensor filter-list cdp list manual-cdp-list
tlv name device-name
tlv name address-type
tlv name capabilities-type
tlv name platform-type
device-sensor filter-list lldp list manual-lldp-list
tlv name system-name
tlv name system-description
device-sensor filter-list dhcp list manual-dhcp-list
option name host-name
option name default-ip-ttl
option name requested-address
option name parameter-request-list
option name class-identifier
option name client-identifier
device-sensor filter-spec dhcp include list manual-dhcp-list
device-sensor filter-spec lldp include list manual-lldp-list
device-sensor filter-spec cdp include list manual-cdp-list
device-sensor accounting
device-sensor notify all-changes
SNMP:
snmp trap mac-notification change added
snmp trap mac-notification change removed
snmp-server host 192.168.101.169 public
I see ISE receives the CDP LLDP info, but is not profiling the endpoint correctly (under context visibility endpoint details):
cdpCacheDeviceId    APCC16.7E98.7A2C
cdpCachePlatform    cisco AIR-AP3802I-B-K9
cdpCacheVersion    Cisco AP Software, ap3g3-k9w8 Version: 8.5.110.0 Technical Support: http://www.cisco.com/techsupport Copyright (c) 2014-2015 by Cisco Systems, Inc.
but in the logs and main context visibility page it is classified as a Cisco-Switch
After reviewing the complete list of attributes of the endpoints, it appears that the endpoint is not performing authentication so IOS device sensor is unlikely at work and, instead, the attributes are gathered by SNMP probe.
I've open CSCvj77125 to track the issue of CDP platform strings for the newer Cisco APs.
7 Replies 7
Arne Bier
Do you send Radius Accounting to ISE PSN?  The Device Sensor data is contained inside the Radius Accounting Cisco AVPairs.
Thank you, Arne.  I do have this configured, but oddly it isn't showing up in the running-config.  I enabled debug:
*May 30 23:57:34.464: RADIUS/DECODE(0000117F): There is no General DB. Reply server details may not be recorded
*May 30 23:57:34.464: RADIUS(0000117F): Unique id not in use
*May 30 23:57:34.464: RADIUS/DECODE(0000117F): There is no RADIUS DB Some Radius attributes may not be stored
*May 30 23:57:35.871: RADIUS/ENCODE(00001180):Orig. component type = CTS
If your radius servers are not showing up in the running config then alarm bells should be ringing!  IOS can hide config defaults and that is normal, but your aaa config should always be visible.  Perhaps there is an additional command to include VSA' in the Radius accounting (I have a vague memory of this ... you have to tell IOS what all to include in the Accounting requests).
Can you share your relevant aaa IOS config?
They are showing up and authen/authorization is working:
aaa group server radius dnac-client-radius-group
server name dnac-radius_192.168.101.179
ip radius source-interface Loopback0
aaa authentication dot1x default group dnac-client-radius-group
aaa authorization network default group dnac-client-radius-group
aaa authorization network dnac-cts-list group dnac-client-radius-group
aaa accounting dot1x default start-stop group dnac-client-radius-group
aaa server radius dynamic-author
client 172.25.0.179 server-key notforyou2
client 192.168.101.179 server-key notforyou2
client 172.25.0.178 server-key notforyou2
snmp-server enable traps trustsec-server radius-server provision-secret
radius-server attribute 6 on-for-login-auth
radius-server attribute 6 support-multiple
radius-server attribute 8 include-in-access-req
radius-server attribute 25 access-request include
radius-server dead-criteria time 5 tries 3
radius-server deadtime 30
radius server dnac-radius_192.168.101.179
address ipv4 192.168.101.179 auth-port 1812 acct-port 1813
timeout 2
retransmit 1
pac key notforyou2
METRO-A5#sh radius server-group all
Server group radius
    Sharecount = 1  sg_unconfigured = FALSE
    Type = standard  Memlocks = 1
    Server(192.168.101.179:1812,1813) Transactions:
    Authen: 0    Author: 0    Acct: 0
    Server_auto_test_enabled: FALSE
     Keywrap enabled: FALSE
Server group dnac-client-radius-group
    Authen: 6228    Author: 61    Acct: 44771
Perhaps there is a command missing in the AP config.  Sorry I don't have experience with this.
I would run a tcpdump on the ISE PSN node and look for your accounting requests from your Cisco AP.  If the AP is sending the Cisco AVPair then it should be visible in the tcpdump.  If not, then it's not an ISE issue.  I have included an example from a Cisco 5520 WLC below which has device sensor enabled.
hslai
If this is a lab, please post the complete list of attributes for this endpoint. Or, you may unicast me the info and, if available, along with the profiler.log file (profiler in DEBUG).
I am guessing other attributes, such as LLDP and NMAP, making it as Cisco-Switch.
