Difference between ACL
silviu1983
Frequent Visitor
Frequent Visitor
Hy,
I have noticed some difference in creating ACL
i mean i have the following lab
Capture.JPGin the upper middle router when i create
access-list 2 deny 10.90.0.0       0.0.255.255   -   nothing happens , which is as expected
but, when i type
access-list 1 deny 10.90.0.0    0.0.255.255     -  it gets applied imediatelly no matter what i do and i cannot ping from any hosts to any host
so my question is. why acces-list 1 gets applied imediatelly without assign it  on a interface with the
ip access-group - command?
Seb Rupik
Hi there,
There is nothing special about access-list number 1.
Can you share the full config of the router with us?
cheers,
Seb.
Building configuration...
Current configuration : 919 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
no ip cef
no ipv6 cef
spanning-tree mode pvst
interface FastEthernet0/0
ip address 192.168.0.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.90.0.1 255.255.0.0
duplex auto
speed auto
interface Serial0/1/0
ip address 192.168.10.1 255.255.255.0
ip access-group 110 out
clock rate 4000000
interface Serial0/1/1
no ip address
clock rate 4000000
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip route 192.168.20.0 255.255.255.0 192.168.10.2
ip flow-export version 9
access-list 110 deny ip host 192.168.0.2 host 192.168.20.9
access-list 110 permit ip any any
line con 0
logging synchronous
line aux 0
line vty 0 4
login
end
