Difference between AnyConnect ISE Posture and Posture Module
laurathaqi
Level 6
Level 6
Dear community,
What is the difference between ISEPosture Module and Posture module which are found on the AnyConnect pre-deploy package. Please see image attached, with the highlighted note.  
Thank you,
Laura
Hi @laurathaqi The AnyConnect Posture module (hostscsan) is used when posturing with the ASA only. Compared to the AnyConnect ISE Posture module which is only used with ISE to perform a posture assessment. They should not be used together.
