Difference between two ISE 1.3 patches
Mohammad Azharuddin
Hi Team,
One of my customers downloaded ISE 1.3 patch 7 sometime back. The files was:
ise-patchbundle-1.3.0.876-Patch7-180002.x86_64.tar
But now the file on the CCO is:
ise-patchbundle-1.3.0.876-Patch7-186268.x86_64.tar
So, we wanted to know the difference between these two:
ise-patchbundle-1.3.0.876-Patch7-180002.x86_64.tar vs ise-patchbundle-1.3.0.876-Patch7-186268.x86_64.tar
Regards:
Azhar
Mohammad Azharuddin
Hi Team,
Got a reply on this:
Apparently they reposted ISE 1.3 Patch 7 to CCO due to CSCva22237 – replication fails when customer upgrades from various patches to 1.3 Patch 7.
The release notes detailing the patch can be found @ Release Notes for Cisco Identity Services Engine, Release 1.3 - Cisco
Regards:
Azhar
Geevarghese Cheria
Hi Mohammad,
   Moved your post under Identity Services Engine (ISE) community so that it will give more visibility for engineers handling ISE.
Thanks and Regards,
Geevarghese
Mohammad Azharuddin
Hi Team,
Regards:
Azhar
