Dot1x clients not authenticated after reload
Joris Deprouw
Hi all,
I have a switch setup with dynamic vlan assignment. Everything works fine until the switch is rebooted. Then none of the pc's are authenticated anymore. I have to do a shut/no shut of all the user ports to start the re-authentication of the pc's.
This is the config I have so far. Am I missing something?
Best Regards,
Joris
Global commands
aaa new-model
aaa authentication dot1x default group radius
aaa authorization network default group radius
aaa accounting dot1x default start-stop group radius
aaa accounting system default start-stop group radius
aaa authorization exec default local if-authenticated
aaa authorization commands 1 default local if-authenticated
aaa authorization commands 15 default local if-authenticated
dot1x system-auth-control
dot1x guest-vlan supplicant
dot1x critical eapol
radius-server host x.x.x.x auth-port 1645 acct-port 1646 key *****
radius-server vsa send accounting
radius-server vsa send authentication
Interface-specific commands
switchport mode access
switchport nonegotiate
switchport port-security maximum 5
switchport port-security violation restrict
authentication event fail action authorize vlan 200
authentication event server dead action authorize vlan 110
authentication event no-response action authorize vlan 200
authentication order mab dot1x
authentication priority dot1x mab
authentication port-control auto
authentication periodic
mab
no snmp trap link-status
dot1x pae authenticator
dot1x timeout quiet-period 3
dot1x timeout tx-period 3
dot1x max-req 1
storm-control broadcast level 1.00
storm-control multicast level 1.00
storm-control action shutdown
storm-control action trap
no cdp enable
no cdp tlv server-location
no cdp tlv app
spanning-tree portfast
PAUL SHELTON
I believe you will need to tell your ports what action to take when the AAA server becomes available. It knows what to do when it's dead or unavailable, but has the default setting when it is returned to service. Likely the switch is tripping AAA dead or non-responsive for a bit during boot and its a race. You want the port to reauth when the AAA server becomes avail.
Hello Paul,
So If I add the following line to my interface specific config it should be ok.
"authentication timer reauthenticate server"
I'll give it a try.
Best Regards,
Joris
PAUL SHELTON
More like
Authentication event server alive action reinitialize (or reauthenticate). It's an R word. The command is definitely an auth event command not a timer however. Think of it as post failure recovery.
