Dot1x port-control auto protocol down (ACS5.3)
cameroun
Hello everyone!
I urgently need your help please.
I would like to configure the ports of a switch for 802.1x.
when I type the command: Dot1x harbor auto-control on the interface, the protocol is down and users are disconnected wiring.
Can someone help me please? it is really urgent.
thank you in advance
edwardcollins7
Is this the command that you are using ?
"Dot1x harbor auto-control"
What else do you have for dot1x on this device?
Rate if Useful :)
Sharing knowledge makes you Immortal.
Ed
hello
thank you for your answer.
bellow is the configuration  that i've configured on the switchs:
configure terminal
  aaa new-model
  aaa authentication dot1x default group radius
  interface fastethernet0/1
  dot1x port-control auto
  end
 radius-server host x.x.x.x auth-port 1612 key xxxx
but the command : dot1x port-control auto , cause protocol dows but the port status is UP.
I did not understand the function of this command:"Dot1x harbor auto-control"
could you tell me a little more?
thank you in advance.
