Extreme Networks Wireless integration with Cisco ISE
ysilva97
Hello everyone! How are you?
I am performing some tests on my network by integrating an AP305C from Extreme Networks with Cisco ISE to perform corporate network authentication and later for guest networks.
Can anyone who has already done this configuration guide me or direct me on how it was configured on the ISE side to support this third-party equipment? I have already imported the Extreme dictionary and followed other documents, but without success.
Base link: https://community.cisco.com/t5/security-knowledge-base/ise-2-4-posture-using-snmp-coa-with-extreme-switches/ta-p/3641460
If anyone has done this and can support me, I would be grateful.
https://cs.co/ise-interop
RADIUS is RADIUS what do you mean by "corporate network authentication"?  EAP?  What EAP method?  Guest is going to be tricky since Extreme doesn't support dynamic URL redirection.  You will need to use the ISE integrated DHCP/DNS server or use something else for Guest.
dal
Level 3
Level 3
We have run Aerohive / Extreme Accesspoints with Cisco ISE as the radius server for years.
What do you want to know?
