For AD to ISE integration using domain joint, do we need to join all nodes or just the primary node?
fkaleem
Hi All,
We have four node currently in our deployment, PAN primary and PAN secondary. MnT Primary and MnT secondary. Then two dedicated PSN.  Thanks
Arne Bier
It depends what you're using AD for.  If you need AD for your PSN Policies, then technically speaking, you only need to join your two PSN nodes to the AD domain. However, if you want your ISE node Web Admin logins to use AD then you need to join all the nodes.
One bug I found in this respect is that if you selectively join only a subset of nodes to AD, then ISE will complain bitterly that the remaining ISE nodes have not joined the AD domain.  You can disable this, but then you will not be notified of a real issue with your PSN's if they should have AD issues.
So, my advice is to join ALL the ISE nodes because
1) Web admin to all ISE nodes with controlled AD creds is a good idea
2) Stop the stupid AD 'not-Joined' alarms from occurring
Arne Bier
Many Thanks Arne for your excellent and timely assistance.
