Help - Ordering 4.1 upgrade for ACS
johngething
Hi all, Just loaded 4.0 but now require 4.1. I've tried ordering through the Product Upgrade tool but have had no emails nor have i had any confirmation when the order is arriving! could someone pls tell me how on erath i'm surpose to check it????? i've tried all the order tools but none seem to work for me! :(
Jagdeep Gambhir
Level 10
Level 10
Hi John,
To get ACS software 4.1 you need to open a TAC case as acs software are not available through upgrade tool.
Thanks for the reply - but i did see 4.1 on the upgrade tool and seemed to have oreder it! but i will check out going through TAC. Many thanks
