Help PIX and freeradius
cyakpovi
HI
I have a problem with my configuration. can someone help.
I have a freeradius, pix and vpn client and i install the radius to authenticate the vpn users. i tested the authentication from the pix to the radius OK but if I want the vpn user to authenticate, after doing tcpdump on the radius server I can see the request coming from the pix but the request cannot go back to the pix. can someone help.
NB: I can authenticate the ssh connection but not the vpn.
thanks
carrel
---------------------- part of the configuration concerning my pb -------------
aaa-server RADIUS protocol radius
aaa-server RADIUS host 192.168.1.40
retry-interval 2
timeout 2
key vpn
authentication-port 1812
accounting-port 1813
aaa authentication ssh console RADIUS
sysopt connection permit-ipsec
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto dynamic-map vpn 20 set transform-set ESP-AES-256-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic vpn
crypto map outside_map interface outside
crypto map outside_map client authentication RADIUS
isakmp enable outside
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption aes-256
isakmp policy 20 hash sha
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
ip local pool staffpool 10.33.11.1-10.33.11.254
vpngroup groupstaff address-pool staffpool
vpngroup groupstaff password **********
the log is attached
Not applicable
