Help please with TACACS authentication from a Nexus 5548
Paul Murray
I cannot get login working via TACACS from my Nexus 5548.  I've tried creating a group and a single server with key etc.
Config is simple:
tacacs-server key 7  ************
ip tacacs source-interface Vlanx
aaa group server tacacs+ tacacs
    server 10.x.y.z
The test aaa command shows it's authenticating:
NEX01# test aaa server tacacs+  10.x.y.z <username> <password)
user has been authenticated
Debug shows this:
NEX01# 2011 Jun  8 12:31:03 NEX01 %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user <username>  from 10.x.y.z- login[1691]
Am I doing something glaringly wrong here?
Any advice is greatly appreciated.
Thank you.
Waris Hussain
Hi Paul,
Looks like may be the packet dont have the route ACS when you try to login .
Can you share sh run of the switch  ?
Also do you see failed attempt on tacacs server side. ?
Can you ping tacacs server with source interface Vlanx?
Waris Hussain
