help with AAA config- stuck and need assistance
mjsully
I have an ASA firewall in which I need these requirements.
There will be three local accounts defined on the ASA. I need one of these accounts to have to enter an enable password when accessing privileged enable mode. The other two accounts I want to take directly to privileged mode after authenticating with their local username and password. All connections to the ASA will be via SSH, if that matters. How do I set this up?
Jagdeep Gambhir
Level 10
Level 10
In ASA user cannot fall directly to enable mode since exec authorization is not supported.
Please see this link,
http://www.ciscotaccc.com/security/showcase?case=K25224726
~JG
Do rate helpful posts
but doesn't this pertain to TACACS+ and RADIUS authentication? All my accounts are locally defined on the ASA itself, nothing goes to an external authentication server.
It also applicable for local authentication. ASA does not perform exec authorization, no matter what db or protocol we use.
~JG
