how to authorize switch port when ISE is down
kareali@cisco.com
   i'm trying to implement how to authorize the switch port when ISE nodes are dead
i tried some commands but i see that only one endpoint can work ip phone or pc ?
authentication event server dead action authorize vlan x
authentication event server alive action authorize voice
authentication host-mode multi-domain
so is there a way to authorize both endpoints when ISE is dead ? can i use service policy for example ?
17 Replies 17
global configuration
aaa new-model
username ISERADIUSTEST password ISEtest123
radius server Abb-ISE
address ipv4 x.x.x.x auth-port 1645 acct-port 1646
automate-tester username ISERADIUSTEST idle-time 15
key CSO@citc!
exit
radius server Oct-ISE
address ipv4 y.y.y.y auth-port 1645 acct-port 1646
key CSO@citc!
exit
aaa group server radius ISE
server name Abb-ISE
server name Oct-ISE
deadtime 10
exit
aaa server radius dynamic-author
client x.x.x.x server-key CSO@citc!
client y.y.y.y server-key CSO@citc!
exit
aaa authentication dot1x default group ISE
aaa authorization network default group ISE
aaa accounting dot1x default start-stop group ISE
aaa accounting network default start-stop group ISE
aaa accounting delay-start all
aaa accounting update newinfo periodic 60
radius-server attribute 6 on-for-login-auth
radius-server attribute 8 include-in-access-req
radius-server attribute 25 access-request include
radius-server vsa send authentication
radius-server vsa send accounting
ip radius source-interface vlanxx
ip dhcp snooping
ip device tracking
epm logging
logging origin-id ip
logging source-interface Vlanxx
logging host 10.10.81.81 transport udp port 20514
logging host 20.10.81.81 transport udp port 20514
dot1x system-auth-control
dot1x critical eapol
ip http server
ip http secure-server
ip access-list extended redirection
permit tcp any any eq 80
permit tcp any any eq 443
permit tcp any any eq 8905
permit ip any host 1.1.1.1
deny ip any any
exit
mac address-table notification change
mac address-table notification mac-move
snmp-server trap-source vlanxx
snmp-server community CSO@citc! RO
snmp-server enable traps mac-notification change move threshold
snmp-server enable traps errdisable
snmp-server enable traps vlan-membership
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server host 10.10.81.40 version 2c CSO@citc! mac-notification snmp
snmp-server host 20.10.81.40 version 2c CSO@citc! mac-notification snmp
interface GigabitEthernet w/x/y-z
switchport access vlan X
switchport voice vlan y
switchport mode access
authentication event fail action next-method
authentication event server dead action authorize vlan X
authentication event server dead action authorize voice
dot1x pae authenticator
dot1x port-control auto
authentication order dot1x mab
authentication priority dot1x mab
mab
dot1x timeout tx-period 10
authentication periodic
authentication timer reauthenticate server
snmp trap mac-notification change added
spanning-tree portfast
exit
Does this configuration allows both vlans ie data and voice? because i have same scenario but IP phone connects to the switch and PC connects to an IP phone.
vibobrov
The correct command is authentication event server dead action authorize voice
