How to integrate cisco ISE 2.2 with Symantec VIP for wireless authentication ?
reachmearun.s
I found a document https://communities.cisco.com/docs/DOC-68200 but this options are not available in ISE 2.2
kvenkata1
Hi Arun,
The document was based on an earlier ISE version & hence you may not find all the options. Unless there is a solid business case, there is no plan to update the document.
- Krish
