Integration problem between ACS 5 and AD 2012
ramikamel911
Level 2
Level 2
Hi Guys,
ACS 5.5 is installed on SNS-3415 appliance.
Integration with Active Directory 2012 has been successfully completed.
The problem which I'm facing that i can't see all the groups of AD under ACS, i see only few of them.
Also if i created new Group in AD, i can't see it in ACS.
I tried to add it manually on ACS, but still it is not working.
Any clue?
Rami
mohanak
if you are having older version then Upgrade the ACS version to 5.5.0.46.4 and verify
Thanks for your reply, already did but problem not resolved.
hdussa
Level 4
Level 4
Hi Rami,
what kind of group is it. ACS support only LOCAL & GLOBAL groups.
