integration problems with ISE
jean-souza
Frequent Visitor
Frequent Visitor
Could you please provide us with support? We are currently facing authentication issues with Cisco ISE after enabling biometric and facial recognition login for our users.
Since the biometric feature was enabled, we have noticed that Cisco ISE frequently keeps requesting authentication and, in many cases, ends up locking the user accounts.
Please note that:
  • The biometric service is fully operational and available to all users;
  • Biometric authentication is not integrated with Cisco ISE;
  • The external platform currently in use is Microsoft Intune.
Please find attached an image showing the Cisco ISE version in use:
2 Accepted Solutions
Why are you using EAP-FAST? Why not TEAP? Also that is an ANCIENT patch of 3.2. Please install the latest 3.2 patch before doing spending any more time troubleshooting this. Also: https://www.cisco.com/c/en/us/products/collateral/security/identity-services-engine/identity-service-engine-software-3-1-3-2.html
Again though, this is an endpoint configuration problem, not really an ISE problem.
  @jean-souza Moving towards TEAP is anyways a smart decision for the long run. Aside to this aspect, you'd have to move your EAP-FAST or TEAP to use EAP-TLS for this to work as intended: https://learn.microsoft.com/en-us/windows/security/identity-protection/hello-for-business/
Cristian.
This is 100% an endpoint problem. Not an ISE problem. What EAP method is used? EAP-TLS? TEAP? PEAP MS-CHAPv2? Something else?
The screenshot is for Cisco Secure Client, not ISE. But why are you using 5.0 and not 5.1?
The EAP method used is EAP-FAST.  And the version of ISE is the one in the image below:
Cristian.
