ISE 1.2 web authentication problem with wired clients
alex.dersch
Level 4
Level 4
i am having problems with centralized web authentication using a Catalyst 3650X with IOS 15.0.2 SE01 and ISE 1.2.
Redirecting the client works fine, but as soon the client opens a web browser and ISE websites open to authenticate the client, the switch port resets, the authentication process restarts and the session ID changes. After the client enters the credentials a session expired messages appears on the client and i get an 86017 Session Missing message in ISE.
here the output form the debug aaa coa log.
Any ideas
thanks in advanced
Alex
! CLIENT CONNECT TO SWITCHPORT
ISE-TEST-SWITCH#show authentication sessions interface gi0/3
            Interface:  GigabitEthernet0/3
          MAC Address:  001f.297b.bd82
           IP Address:  10.2.12.45
            User-Name:  00-1F-29-7B-BD-82
               Status:  Authz Success
               Domain:  DATA
      Security Policy:  Should Secure
      Security Status:  Unsecure
       Oper host mode:  multi-auth
     Oper control dir:  both
        Authorized By:  Authentication Server
          Vlan Policy:  N/A
              ACS ACL:  xACSACLx-IP-PERMIT_ALL_TRAFFIC-537cb1d6
     URL Redirect ACL:  ACL-WEBAUTH-REDIRECT
         URL Redirect:  https://nos-ch-wbn-ise1.nosergroup.lan:8443/guestportal/gateway?sessionId=AC1484640000026B28C02CDC&action=cwa
      Session timeout:  N/A
         Idle timeout:  N/A
    Common Session ID:  AC1484640000026B28C02CDC
      Acct Session ID:  0x0000029C
               Handle:  0x8C00026C
Runnable methods list:
       Method   State
       dot1x    Failed over
       mab      Authc Success
! CLIENT OPENS INTERNETEXPLORER -> REDIRECTS TO ISE
! SWITCHPORT GOES IN ADMINISTRATIVE DOWN STARTS AUTHENTICATION AGAIN
ISE-TEST-SWITCH#
191526: .Jun 24 10:42:24.340 UTC: COA: 10.0.128.38 request queued
191527: .Jun 24 10:42:24.340 UTC: RADIUS:  authenticator 7F A9 85 AB F6 4A D0 F3 - B4 E6 F2 56 74 C6 2D 33
191528: .Jun 24 10:42:24.340 UTC: RADIUS:  NAS-IP-Address      [4]   6   172.20.132.100
191529: .Jun 24 10:42:24.340 UTC: RADIUS:  Calling-Station-Id  [31]  19  "00:1F:29:7B:BD:82"
191530: .Jun 24 10:42:24.340 UTC: RADIUS:  Acct-Terminate-Cause[49]  6   admin-reset               [6]
191531: .Jun 24 10:42:24.340 UTC: RADIUS:  Event-Timestamp     [55]  6   1403606529
191532: .Jun 24 10:42:24.340 UTC: RADIUS:  Message-Authenticato[80]  18
191533: .Jun 24 10:42:24.340 UTC: RADIUS:   E0 3C B2 8C 89 47 67 A8 69 F5 3D 08 61 FF 53 6E          [ <Ggi=aSn]
191534: .Jun 24 10:42:24.340 UTC: RADIUS:  Vendor, Cisco       [26]  43
191535: .Jun 24 10:42:24.340 UTC: RADIUS:   Cisco AVpair       [1]   37  "subscriber:command=bounce-host-port"
191536: .Jun 24 10:42:24.340 UTC: COA: Message Authenticator decode passed
191537: .Jun 24 10:42:24.340 UTC:  ++++++ CoA Attribute List ++++++
191538: .Jun 24 10:42:24.340 UTC: 06D96C58 0 00000001 nas-ip-address(600) 4 172.20.132.100
191539: .Jun 24 10:42:24.349 UTC: 06D9AC18 0 00000081 formatted-clid(37) 17 00:1F:29:7B:BD:82
191540: .Jun 24 10:42:24.349 UTC: 06D9AC4C 0 00000001 disc-cause(434) 4 admin-reset
191541: .Jun 24 10:42:24.349 UTC: 06D9AC80 0 00000001 Event-Timestamp(445) 4 1403606529(53A95601)
191542: .Jun 24 10:42:24.349 UTC: 06D9ACB4 0 00000081 ssg-command-code(490) 1 33
191543: .Jun 24 10:42:24.349 UTC:
191544: .Jun 24 2014 10:42:24.365 UTC: %EPM-6-IPEVENT: IP 10.2.12.45| MAC 001f.297b.bd82| AuditSessionID AC1484640000026B28C02CDC| AUTHTYPE DOT1X| EVENT IP-RELEASE
191545: .Jun 24 2014 10:42:24.382 UTC: %EPM-6-IPEVENT: IP 10.2.12.45| MAC 001f.297b.bd82| AuditSessionID AC1484640000026B28C02CDC| AUTHTYPE DOT1X| EVENT IP-WAIT
191546: .Jun 24 2014 10:42:24.382 UTC: %EPM-6-POLICY_REQ: IP 0.0.0.0| MAC 001f.297b.bd82| AuditSessionID AC1484640000026B28C02CDC| AUTHTYPE DOT1X| EVENT REMOVE
191547: .Jun 24 2014 10:42:24.390 UTC: %EPM-6-AUTH_ACL: POLICY Auth-Default-ACL-OPEN| EVENT DETACH-SUCCESS
191548: .Jun 24 2014 10:42:26.353 UTC: %LINK-5-CHANGED: Interface GigabitEthernet0/3, changed state to administratively down
191549: .Jun 24 2014 10:42:27.359 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/3, changed state to down
ISE-TEST-SWITCH#
191550: .Jun 24 2014 10:42:36.366 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet0/3, changed state to down
191551: .Jun 24 10:42:40.592 UTC: AAA/BIND(000002A7): Bind i/f
191552: .Jun 24 2014 10:42:41.129 UTC: %AUTHMGR-5-START: Starting 'dot1x' for client (001f.297b.bd82) on Interface Gi0/3 AuditSessionID AC1484640000026C28C2FA05
191553: .Jun 24 2014 10:42:42.580 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet0/3, changed state to up
191554: .Jun 24 2014 10:42:43.586 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/3, changed state to up
! SESSION ID CHANGES, USER ENTERS CREDENTIALS
! ERROR MESSAGE AT CLIENT "YOUR SESSION HAS EXPIRED"
! ERROR MESSAGE IN ISE "86017 SESSION MISSING"
               Status:  Running
               Domain:  UNKNOWN
         Idle timeout:  N/A
    Common Session ID:  AC1484640000026C28C2FA05
      Acct Session ID:  0x0000029D
               Handle:  0x2C00026D
       Method   State
       dot1x    Running
       mab      Not run
Poonam Garg
Level 3
Level 3
Hello Alex,
This generally occurs when you place your phase 2 authorization policy below phase 1 authorization policy. As the authorization policies are matched just like ACl, your client after authorized to phase 1 policy( having redirect acl and all), when re-initiated a authentication and authorization, it is again matching phase 1 authorization policy instead of phase 2 authorization policy, and client is forced to re-authenticate to guest portal again.
I suggest you to move the phase 2 authorization policy above phase 1 policy.
"Please rate helpful posts"
mohanak
Guest authentication failed: 86017: Session cache entry missing
try adjusting the UTC timezone during the guest creation in the sponsor portal.
86017GuestSession MissingSession ID missing. Please contact your System Administrator.Info
nspasov
Can you post a screenshot of your AAA policies from ISE?
Thank you for rating helpful posts!
