ISE 2.1: Posture analysis when using Easy Connect and SNMP COA?
berossig
Hi experts,
When using easy connect with 2.1, can we also do posture while leveraging SNMP COA? Customer is replacing current NAC solution (Symantec), does not want to have to configure the switches (or very minimum configuration), but requires posture assessment prior to let user accessing the network. So can we support that using EasyConnect + SNMP COA?
thank you in advance.
Best Regards,
Benjamin
Craig Hyps
Level 10
Level 10
Posture + Easy Connect was QA tested.  Posture + 3rd-party support was QA tested.  However, combination of Easy Connect + 3rd-Party was not specifically QA tested so cannot claim support.  (SNMP CoA is part of 3rd-party testing.)  It may work, but best to test your specific configuration in lab.
/Craig
Craig Hyps
Level 10
Level 10
/Craig
thanks Craig!
Ben
