ISE 2.2 and Wireless Guest networks using Anchor WLC
clark_collins
I'm not sure if this is best practice anymore, but wanted to see if there was any How-To documents on my topic.  I know in pre-ISE days, you would use an Anchor WLC to place the Wireless Guest in a DMZ network and user Prime Infrastructure to manage the Guests on WLCs.  Is the Anchor WLC still being used with ISE 2.2 and Wireless Guest/BYOD, or has the Anchor WLC gone bye-bye?  If the Anchor WLC is still usable, is there any design guides or How-To's with ISE 2.2 as part of the deployment?
The Mobility Guides I have found so far, use Anchor WLC and Prime Infrastructure.  I would like to see some How-To's or Design Guides with ISE 2.2 to manage the Guest users and have the Anchor WLC to DMZ the Guest users.  Any suggestions?
Thank you
howon
It has been supported for a while with ISE CWA. See last page of the how-to:
How To: Universal Wireless Controller (WLC) Configuration for ISE
gbekmezi-DD
Level 5
Level 5
I don’t think ISE would influence that design unless you are doing end to end segmentation with SGTs (which I would question) for guest traffic.
howon
