ISE 2.3 - Posture - Endpoint compliance with temporal agent issue
gabrieleferrari
We are working with ISE 2.3 and Posture assesment feature.
To allow network access to a specific client we need to verify the following statement:
-Specific application are NOT  present on the system (i.e. nmap.exe)
In this environment we can't use Anyconnect, is mandatory the use of Temporal Agent
From my point of view the only way to verify the absence of a specific application to create a posture remediation action with the manual uninstall option configured, but this requires the use of Anyconnect.
Does anybody knows how to archive this goal?
Best regards
Gabriele
maybe I found the solution to my question.
In ISE an application condition defined always check for "malicious" software on the endpoint, so the behaviour described is always true.
Is it correct?
hslai
Although Temporal agents do not support remediations triggered by a button in the agent UI, we may show a message text and ask the users to manual perform the actions. Attached shows an example of failing the windows firewall condition.
Video Link : 16637
Thanks for your reply.
Unfortunately I need to verify the presence of a software and, if present, deny the access to the user.
The condition that I need to verify is similar to this:
if (7zip is [installed | running])
than non compiant
else compliant
Consider 7zip a generic example of a specific application
Is it correct?
Yes, that is correct.
