07-11-2024 12:20 AM
since we've updated ISE to 3.3 p2 we have some Problems with snmp v3.
on the prod devices (SNS 3615) it was ok after Firmware Upgrade, but on the Test (VMWare) I can get snmp v3 to work:
snmp-server enable
snmp-server contact some-adress
snmp-server engineid xxx
snmp-server location VMWARE
snmp-server user user1 v3 sha1 hash ********** **********
snmp-server user user2 v3 sha1 hash ********** **********
snmp-server user user3 v3 sha256 hash ********** **********usually, when I do: "no snmp-server enable", the snmp-config should be cleared, but nothing is cleared.
If I change the engineid (I know it's the serialnumber) the snmp-users should be cleared, but nothing is cleared.
If I try to delete the user, I get the message:
sv000400/admin(config)#no snmp-server user ?
Description: Add snmp user
Possible completions:
user1 user2 user2
no snmp-server user user1:
syntax error: incomplete pathif I want to delete the user with complete details:
"Error: element does not exist"
I know about this: https://community.cisco.com/t5/network-access-control/ise-snmpv3-deleting-username-design-flaw/td-p/4683150
But doesn't help.
Any other Ideas?
Thank you
07-15-2024 12:55 AM
If you have a Cisco Support Contract to raise a TAC case, then please do so. I am not a fan of finding workarounds for issues that are in the software. The ISE application has clear defects with regards to how SNMP has been implemented, and despite their recent fixes (and my customers are happy ... so far ... touch wood) there still seems to be some worm larvae in the code. They decide to hatch when customers upgrade their ISE versions.
If you don't have a support contract then try the usual
- reboot the node, then try deleting again
- try adding the same SNMPv3 user account with same auth/priv creds (i.e. overwriting it) - and then try deleting it.
- disable SNMP entirely - then re-enable and then try deleting it
It shouldn't have to be this hard.
