ISE: 3615 appliance and redundant power supply
Stephen Colby
Much like the SNS-3515 which does not come with a redundant power supply, is there a specific part SKU to add a PSU to the SNS-3615?  Is this supported as long as it is not shipped back with an RMA?
Pretty much the same discussion as this thread but for the newer SNS-3615: https://community.cisco.com/t5/identity-services-engine-ise/ise-3515-appliance-and-redundant-power-supply/td-p/3445552
Damien Miller
The spare you want to order is still the same part number for the new m5 hardware, UCSC-PSU1-770W. It will work the same as with the 3515 m4 hardware, don't ship it back or you will be ordering a new one.
Damien Miller
Thanks Damien, that's what i figured but wanted to be 100% sure before ordering. Appreciate the quick feedback.
r1127hyduk
Level 4
Level 4
Good morning All,
Can anyone share the part number for possible power cables for this system - 15a and 6a?  I believe we would prefer the 15a based on how the prongs are up right left / right sides instead of the 6 amp which has the top prongs angled left to right or sideways (if this makes sense)?
