ISE/Active Directory connection info
joconley
Can we get the information located in the TechZone link below updated (if needed) for ISE 2.x and posted to the community?  Customer was looking for this type of information and did not have access to the TechZone article.
https://techzone.cisco.com/t5/Identity-Services-Engine-ISE/ISE-Active-Directory-Facts/ta-p/924971/message-revision/92497…
hslai
The current content is internal only and not suited for general public use. If you need it documented at CCO, please open a doc bug.
Meanwhile, please refer customers to What's new in ISE Active Directory connector (2016 Berlin)
hslai
