ISE and OIM (Oracle Identity Management) integration For SDA
rmaniar
Dear Team,
I would like to check if we can integrate OIM with ISE for SDA and what are the limitations.
Can we write an API to call OIM rest API and built a separate SQL sequel database and then integrate it on ISE? Or do we have any connector?
I would like to know what are the ways we could integrate ISE and OIM.
Ronak
Jason Kunst
It’s not clear what your use case is and how the flow would work can you please expand on that. Also not sure what expectations are around SDA as well? DNAcenter afaik doesn’t automate this
We integrate with saml providers for CWA SSO and have some integration notes on our guest web auth page , likely will work calling out group info from ldap and mapping that to an SGT
https://community.cisco.com/t5/security-documents/ise-guest-amp-web-authentication/ta-p/3657224
Also our compatibility guide
https://www.cisco.com/c/en/us/td/docs/security/ise/2-4/compatibility/b_ise_sdt_24.html
Jason Kunst
