ISE and Wireless compatibiity
jthullen
we are in the process of preparing to upgrade our Wireless Controllers from 7.2.110 to 7.6.130. When I check the ISE compatibility matrix, it does not specifically list 7.6 WLC code as supported on ISE 1.1.4 or ISE 1.2. I assume it is, given 7.5 is listed as supported in the 1.2 matrix. Can you verify that 7.6.130 WLC code is supported in ISE 1.1.4 AND ISE 1.2.1?
2 Accepted Solutions
nspasov
Yes, it is. I have done several ISE deployments with WLCs running 7.6. With that being said, stay away from 7.5. It is not a good code and it is full of issues.
Thank you for rating helpful posts!
No problem! If your issue is resolved please mark the thread as "answered" :)
nspasov
Thank you for that info, much appreciated.
