ISE Authentication issue when configuring both profiling and 802.1x
amr.abdulwahab
Hi all
I have an issue when configuring profiling and 802.1X EAP-TLS at the same time. When configuring EAP-TLS only, users can authenticate using their certificates without any problem.
Once I enable profiling, the MAC address of the EAP-TLS client is recorded into the internal database of ISE, and then the client is authenticated through MAB.
Any idea to solve this issue ?
nspasov
You shoudl be able to accomplish this by changing the authentication priority/order on the switchport(s)
 authentication order dot1x mab
 authentication priority dot1x mab
Hope this helps!
Thank you for rating helpful posts!
