ISE - auto assign a device to group upon device registration
glmharled
Is it possible to auto assign a device to group upon device registration?
Typically in the registration portal, once "Register" button is clicked, the MAC address is put into "Registered Device" group, but let's say I want it to be put in different groups depending on the AD group? (Let's say when if Staff A register the device, the device automatically put into group A, Staff B to group B, and so forth)
jj27
Unfortunately not, but you can use several Authorization rules and profiles to accomplish the same thing.
if RegisteredDevices and AD:ExternalGroup=StaffA then StaffA_Permissions
etc.
hmm, that's the challenge that we're having, if we use AD group then we need to turn on dot1x authentication, while the customer wants to achieve this by using MAB only
Bastien Migette
If you create a portal Specific for device registration, you can define to which ID groups will belong the registered endpoints.
I didn't tried this, but it might be possible to have a different portal for registration based on AD group, if you chain it after CWA or Dot1x. That would make an additional redirection though.
Venkatesh Attuluri
you can Specify Identity Store Sequence Used for  Authentication
Choose Administration > Web Portal Management > Settings > My Devices > Authentication Source.
You need to have an authorization policy to assign these registered devices permission
