ISE in a Hyper-V cluster using Storage Spaces Direct Hyper-V cluster
Scott Fella
I want to understand if I can install ISE in a Hyper-V cluster using Storage Spaces Direct Hyper-V cluster, or would I just implement individual Hyper-V instances?  The plan initially is to have 4 nodes, two PAN/MNT and two PSN's.  There will be located in two separate DC's and in each data center, we will have two Hyper-V servers using Storage Spaces Direct Hyper-V cluster.  Basically each server would just mirror the storage of the other.
-Scott
Scott Fella
Just got some information from the BU and they do not yet support Hyper-V cluster.
-Scott
Scott Fella
-Scott
Hello guys.
I just deployed two ISE nodes in Hyper-V cluster and we are facing connectivity issues between them. The version I used is 3.2.
Any recommendations related Hyper-V?
