ISE Indexing Engine is not running.
jose.garcia1
I get an error in the ISE console indicating the ISE Indexing Engine is not running.
When I run show application status ise in the cli I get the below screen shot.
I have tried to start and stop the ISE as well as rebooting the ISE appliance.
Can anyone provide info on how to resolve this issue.
21 Replies 21
same issue....
dns records are persist/ Certificates installed, time zone, NTP correct....
tried restart...no luck(
ise/admin# ping ise
PING ise (10.0.64.228) 56(84) bytes of data.
64 bytes from 10.0.64.228: icmp_seq=1 ttl=64 time=0.028 ms
64 bytes from 10.0.64.228: icmp_seq=2 ttl=64 time=0.028 ms
64 bytes from 10.0.64.228: icmp_seq=3 ttl=64 time=0.020 ms
64 bytes from 10.0.64.228: icmp_seq=4 ttl=64 time=0.039 ms
--- ise ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3001ms
rtt min/avg/max/mdev = 0.020/0.028/0.039/0.009 ms
ise/admin# sh clock
Mon Jun 17 14:39:34 MSK 2019
ise/admin#
ise/admin# sh ntp
Configured NTP Servers:
10.0.64.1
10.101.0.136
10.101.0.137
synchronised to NTP server (10.101.0.137) at stratum 3
time correct to within 474 ms
polling server every 64 s
remote refid st t when poll reach delay offset jitter
127.127.1.0 .LOCL. 10 l 87 64 76 0.000 0.000 0.000
+10.0.64.1 89.109.251.21 2 u 13 64 77 2.341 -3.561 0.318
+10.101.0.136 194.190.168.1 2 u 12 64 77 0.555 -0.015 0.635
*10.101.0.137 89.175.20.7 2 u 14 64 77 0.581 -2.561 0.628
i fixed it
ise/admin# application configure ise
Selection configuration option
[1]Reset M&T Session Database
[2]Rebuild M&T Unusable Indexes
[3]Purge M&T Operational Data
[4]Reset M&T Database
[5]Refresh Database Statistics
[6]Display Profiler Statistics
[7]Export Internal CA Store
[8]Import Internal CA Store
[9]Create Missing Config Indexes
[10]Create Missing M&T Indexes
[11]Enable/Disable ACS Migration
[12]Generate Daily KPM Stats
[13]Generate KPM Stats for last 8 Weeks
[14]Enable/Disable Counter Attribute Collection
[15]View Admin Users
[16]Get all Endpoints
[17]Enable/Disable Wifi Setup
[18]Reset Config Wifi Setup
[19]Establish Trust with controller
[20]Reset Context Visibility
[21]Synchronize Context Visibility With Database
[22]Generate Heap Dump
[23]Generate Thread Dump
[24]Force Backup Cancellation
[0]Exit
21
This will synchronize Context Visibility with database. Do you want to proceed [y/n]: y
Copying files
  - Done
Changing permissions
  - Done
Exporting endpoints from database
  - Done
Importing endpoints into context visibility
  - Done
Synchronization of Context Visibility with Oracle is successful
[0]Exit
ise/admin#
ise/admin#
ise/admin#
ise/admin# reload
Save the current ADE-OS running configuration? (yes/no) [yes] ? y
Please enter yes or no
Save the current ADE-OS running configuration? (yes/no) [yes] ? yes
Generating configuration...
Saved the ADE-OS running configuration to startup successfully
Continue with reboot? [y/n] y
Broadcast message from root@ise (pts/1) (Tue Jun 18 08:27:38 2019):
Trying to stop processes gracefully. Reload might take approximately 3 mins
Broadcast message from root@ise (pts/1) (Tue Jun 18 08:29:21 2019):
The system is going down for reboot NOW
Connection was reset.
Last login: Tue Jun 18 08:20:35 2019 from 10.1.63.30
Failed to log in 0 time(s)
ise/admin# sh app sta ise
ISE PROCESS NAME                       STATE            PROCESS ID
Database Listener                      running          2406
Database Server                        running          66 PROCESSES
Application Server                     initializing
Profiler Database                      running          4847
ISE Indexing Engine                    running          13383
AD Connector                           not running
M&T Session Database                   running          4441
M&T Log Processor                      running          11176
Certificate Authority Service          not running
EST Service                            not running
SXP Engine Service                     disabled
Docker Daemon                          running          5645
TC-NAC Service                         disabled
Wifi Setup Helper Container            disabled
pxGrid Infrastructure Service          disabled
pxGrid Publisher Subscriber Service    disabled
pxGrid Connection Manager              disabled
pxGrid Controller                      disabled
PassiveID WMI Service                  not running
PassiveID Syslog Service               not running
PassiveID API Service                  not running
PassiveID Agent Service                not running
PassiveID Endpoint Service             not running
PassiveID SPAN Service                 not running
DHCP Server (dhcpd)                    disabled
DNS Server (named)                     disabled
ISE Messaging Service                  running          6162
Database Server                        running          75 PROCESSES
Application Server                     running          11004
ISE Indexing Engine                    running          6617
AD Connector                           running          22189
Certificate Authority Service          running          18394
EST Service                            running          31272
PassiveID WMI Service                  running          18897
PassiveID Syslog Service               running          19440
PassiveID API Service                  running          20228
PassiveID Agent Service                running          20831
PassiveID Endpoint Service             running          21271
PassiveID SPAN Service                 running          21841
ise/admin#
wrong...after some time...
Database Server running 70 PROCESSES
ISE Indexing Engine not running
Please open a tac case and update thread
any resolution yet EvgenyG?
DNS is not resolved properly. try nslookup to see PTR value. in my environment reverse dns not working. click health check to see the issue. after that
20 & 21 separately. than reload the ise.
