ISE Indexing Engine is not running.
jose.garcia1
I get an error in the ISE console indicating the ISE Indexing Engine is not running.
When I run show application status ise in the cli I get the below screen shot.
I have tried to start and stop the ISE as well as rebooting the ISE appliance.
Can anyone provide info on how to resolve this issue.
4 Accepted Solutions
Timothy Abbott
Jose,
You will need to open a TAC case to further investigate why that process is not starting.
-Tim
Check your reverse dns records for ise nodes. Without them ISE Indexing Engine don''t run in cluster.
jason.emery
The issues I have seen/heard on this are:
1. DNS - forward and reverse DNS must be working - also ISE nodes must have working DNS servers configured..
2. Admin Certificates - make sure all nodes have proper Admin certificate - they can be self-signed
3. Time/Timezone - from CLI - make sure the NTP is working properly and all nodes have the same timezone configured.
Jason
Please open a tac case and update thread
21 Replies 21
Timothy Abbott
Jose,
-Tim
What is the impact when ISE indexing service is not running? Does it impact to device admin feature?
hslai
This provides data for ISE dashboard and ISE context visibility. It has no impact on Device Admin (TACACS+) services.
omer shtivi
Did you find the problem? has the same issue here
BR
Omer Shtivi
It worked!
Thank you very much!
omer shtivi
Solved the problem.
Thanks!
hi
how did you solve it ?
i am getting same service error on v2.3
omer shtivi
Reverse A record.
You need that when you do a ping -a <ISE IP> you get the DNS name.
bingo...!
it is worked .
thanks a lot omer
Muhammad Azhar
I found the same problem  after I upgrading from 2.0.0 to 2.3 ( ISE index engine not running ).
By adding revers DNS record  it  solve the issue. Some time you need to restart the ISE node.
i have cheked all reqs. fresh install. but Index does not starts
ise/admin# ping ise
PING ise (10.0.64.228) 56(84) bytes of data.
64 bytes from 10.0.64.228: icmp_seq=1 ttl=64 time=0.028 ms
64 bytes from 10.0.64.228: icmp_seq=2 ttl=64 time=0.028 ms
64 bytes from 10.0.64.228: icmp_seq=3 ttl=64 time=0.020 ms
64 bytes from 10.0.64.228: icmp_seq=4 ttl=64 time=0.039 ms
--- ise ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3001ms
rtt min/avg/max/mdev = 0.020/0.028/0.039/0.009 ms
ise/admin# sh clock
Mon Jun 17 14:39:34 MSK 2019
ise/admin#
jason.emery
Jason
All nodes in a cluster need to be in the same timezone by design? Where is that written?
