ISE integration with Fortigate for Posture wireless endpoint
sandesh-dhuri
We are using Cisco ISE as NAC solution and using posture, we have fortiAPs for wireless which are managed through fortigate.
We configured the radius on Fortigate, authentication is happening and posture assessment is working, but COA is not working. We have enabled the COA on fortigate, but fortigate is sending COANAK to ISE.Does anyone faced this problem and got it resolved ?
marce1000
  - Check if these info's can help youhttps://docs.fortinet.com/document/fortideceptor/5.3.1/administration-guide/894738/integrate-with-cisco-ise
   M.
What is the COANAK reason? It should be in the ISE logs. What NAD profile are you using for the FortiGate? Most likely the CoA message is not formatted correctly with attributes the FortiGate does not understand.
COANAK reason is nasidentifier-mismatch. we are using Cisco device profile as we have not found anyfortinet device profile and vsa file.
