ISE integration with Nexus Hybrid gateway as PKI solution
vaganesa
Could you please confirm if ISE can support integration of Nexus Hybrid gateway product as PKI solution?
Vaishnavi
Jason Kunst
What is your use case? This is not something we have directly tested
If it’s provisioning certificates to endpoints outside of ISE byod flow then yes it should work
If you’re trying to use with ISE byod then we don’t have a document that integrates but as long it it follows same convention of Microsoft NDES then it may possibly work but it would need to be setup in a lab and verified by customer and or integration partner
Jason Kunst
