ISE Integration with SAP PMS (Patient Management System)
hradhanp
Hi Team
One of our customer (Hospital) wants to integrate ISE with SAP PMS (Patient Management System). While SAP is the front end portal, TIBCO is middleware which supports API for integration with external systems.
The requirement for ISE & SAP PMS integration is as follows:
  1.      When a new patient is admitted to the hospital, the patient information will be updated in the SAP PMS database.
  2.      SAP PMS will make API calls to ISE to create patient user account with below details:
    1.      Patient’s Name
    2.      Patient’s Registered Mobile Number
    3.      Patient’s Email ID
    4.      Patient’s Admission date & time
    5.      Patient’s Discharge date & time
  3.      ISE will create patient user account with time based validity
  4.      ISE will send password to patient’s registered mobile number via SMS
  5.      ISE will allow multiple devices to simultaneously login with single user account
  6.      On patient’s discharge from hospital, user account will be deactivated/deleted from ISE.
Please confirm whether the above mentioned integration between ISE & SAP PMS is feasible using API calls.
Jason Kunst
I already answered this internally on a couple of your posts saying that the api can do this
Jason Kunst
