ISE LDAP Integration - How does ISE check Ldap connection
mmisonne
Level 2
Level 2
Hello
I have a Customer who is worried about LDAP binds and unbinds request from ISE.
He does not want his Ldap to have a lots of Binds open and never closed .
The main question is to know if ISE check regulary the Ldaps connection , and how ?
( Using Bind request, ? Bind search.. Unbind..?)
Any idea about that ?
If you do not know, can you give me which log to look at ?
Michel Misonne
Marvin Rhoads
It does a bind. I haven't seen explicit unbinds in the little bit of testing II did (primarily looking at the LDAP portion of an AD integration vs. a pure LDAP setup).
To resolve any doubt, do a Wireshark packet capture on your LDAP server while performing ISE connections and authentications. The packets don't lie. :)
Indeed packets don't lie...provided that connection is not secure
I checked and found:
-There is no keep-alive between ISE and Ldap.
   i.e. , if there is no authentication, there is absolutely no trafic.
- For 1 user authentication, there is 2 bind done ( Search and authentication) , followed by 2 Undbind 30 sec later.
- If we do manualy a Bind-test, in that case, there is no Unbind , and the connection  may stay open.
    This could cause a pb , specifically, if we do multiple Bind-test .
Michel.
