ISE LDAP Secure - Test Failed to connect: Connection refused for host
Dears.
I have problem with the connection for LDAP Secure (port 636), when i try a test to the connection the message is:
Test Failed to connect: Connection refused for host.
Is this message  a problem connection to the network or connection for the certificate?.
Thanks.
Francisco
hslai
I believe your ISE is unable to open a connection at all. One way to verify it is to get TCPDump.
Recently I saw an issue with an expired LDAP cert and ISE gave:
Test Failed to connect: Certificate or SSL error.
hslai
