ISE on VMware Workstation Unsupported CPU problem
Rami Ibrahim
Level 4
Level 4
Hi Guys,
 I'm trying to install ISE on VMWARE for labing purpose.
 When I install it in VMware Workstation it says that it detects a CPU speed which is less than the minimum 1.9 GHz.
My PC's CPU is 1.19 GHz so is there a way to workaround this and get it installed.
Thank you.
Damien Miller
Your only options are to overclock the cpu and bump the base frequency, or find a different machine.
Overclocking might not be a great idea though since you often lose the stepping and power saving modes. It's been a while since I've done it, maybe things have improved.
Damien Miller
inderjeet452
Level 2
Level 2
I also getting the same issue.
